Replaced Stepper Motors: Z axis issues
M4df4c3
Post by M4df4c3 »
I bought a I3 Pro B from a friend and noticed the previous rods where damaged due to lack of lubricant. I purchased new stepper motors (310mm lead screw length, 8mm diameter, 1.8 degree step angle).
I installed the new motors and steppers can move the extruder carrier up and down without issues.
But the issues starts, once I begin a print. The first layer prints perfect, and then once it begins the 2nd, 3rd, etc. layers, the z axis hops too high, and the layers are too far apart. When the print is finished, it looks like a stretched accordion; very tall, very flimsy and barely intact.
In control, I tried changing the z steps per mm setting from 2560 down to about 2100, this helped slightly, but the setting always resets, and it take over an hour the manually click the LCD button down 500+ steps (I think it needs to be at 1600 or less).
The grooves on the new threaded rods are much thicker than the old ones, so I understand what the problem is. I just hope I don’t have to replace them again. I also cannot find rods with as small as grooves as the originals.
It there a way I can set the z steps per mm in Repetier Host? Or is there another way to changes the z steps per mm? Perhaps in the firmware using Arduino IDE?
Thank you, I am having lots of difficulty with this, anything helps!
-Tony
daisygosia
Re: Replaced Stepper Motors: Z axis issues
Post by daisygosia »
The information is good, i need more, i'm still learning about it.
SamFullerton
Post by SamFullerton »
Get back to school data is an exceptionally enlightening and helpful blog entry. German town school is one of the most eminent and well known schools that are offering essay writing service online for understudie's help. Much obliged for offering this to us. This school has been serving since its beginning.
LeoSeery
Post by LeoSeery »
Digital marketing is the latest technique. And is targeting the large number to visit https://www.locacopy.com/71870-2/ on site of customers in short time. So for the marketers it is the time to learn the basic techniques and to promote the brand and product. I have learned a lot from this blog.
