Cura profile file for A30T
Is there profiles for Cura? I have the profiles for repetier but in some cases Cura would nice.
Re: Cura profile file for A30T
Geeetech is very good for organization, this is right on their homepage under the downloads tab and then "Cura configuration file" - https://www.geeetech.com/download.html?download_id=47rotormansa wrote: Thu Mar 04, 2021 5:01 am Is there profiles for Cura? I have the profiles for repetier but in some cases Cura would nice.
Thanks for this.
where do the A30T.curaprofile and A30_PrimeTower.curaprofile files go or how do you install them?
Just copy and past the folders in the same cura folders.
Then you will have the A30t in the printer liste of cura
Can't copy the curaprofile files to any Cura location, these must be imported via the Cura tool. I figured it out after doing some google searches.
Anyone know how to get the A30T to appear on the drop down list of printers? I have imported the profile files ok, but cant see the A30T in the printers section. Is a json file required?
Vous chercher trop compliquer...
Je l'ai encore fait ce week-end sur mon 2eme pc ....
Installation de cura ensuite il faut juste copier les fichiers des 3 dossiers dans les mêmes dossiers de cura.
Rien à importer juste copier
It won't, I'm not sure how it is decided how those printers get added. But you can select the A20T and then edit the A30T info into it and rename it.ozcanroy wrote: Tue Mar 22, 2022 7:41 pm how to get the A30T to appear on the drop down list of printers?
