Flash firmware over UART RS-232
Hi there,
I have iduino Yun and its network (LAN and WLAN) are not working since I got it from ebay. I tried to flash using TFTP but it does not work bacause of LAN failure.
Does anyone knows how can I flash it using UART or RS-232 - USB what ever?
PS: When I ping it over LAN or wifi it respond only on 2-3 of 100 pings. Something is not ok. Its brand new but does not work.
Thanks.
Thanks.
Re: Flash firmware over UART RS-232
Hi,you can check this link:http://www.geeetech.com/wiki/index.php/ ... uino_Board.
Only buy from trusted sellers on ebay. Poor packaging will cause damage to those boards. I had those experiences.
Anne_Filelinked AC Market_manike
- Contact:
Yes i agree that you must choose the trusted buyers
not ok
i am designer & i found best interior designing company in kolkata
The most common cause of serial port communication problems is incorrect communication parameter settings. To operate correctly it is essential that both devices are set up with the same communication parameters, which includes baud rate, parity, number of data bits, and number of stop bits. thank You. .
No Jailbreak required: Tutubox will entire all demands which you are awaiting from it. Because it has all capabilities that someone wishes. One of the best abilties is, you don’t have any need to jailbreak your iOS device to put in apps and games Install TuTuBox APK. If you've got an Android device then you may installation TutuBox Apk for Android with out root. But if you have a jailbroken iOS device. Then don’t worry, you can also set up this app to your jailbroken tool.
