repair
Olga
repair
Post by Olga »
The dryer door is not blocked
Triksy
Re: repair
Post by Triksy »
First of all, make sure that the handle and hook on the door are not broken, and that the "Childproof" function is off. Also the cause of the problem may be a burned out door lock and a faulty power control module (electronics) - in this https://serviceservotech.com/2017/05/ca ... westmount/ case you should call a master.
