Problem reading temperature Rambo Board
techsupport
Re: Problem reading temperature Rambo Board
Post by techsupport »
you can test the r32 r37 r28 r39 is solded well。the min temp err means that the thermistors is not connected well with mega2560.it is open circuit。
Email: forum@geeetech.com
daxer70
Post by daxer70 »
I'm not expert in dmd soldering, I've only tested all the resistors with the multimeter and always got around 4.3 k value
techsupport
Please see the attached figure,You provide resistance value is normal,
You can check the electronic circuit is normal? waiting your reply.
Best regards
Rambo-T0.T1.rar
(9.56 KiB) Downloaded 603 times
daxer70
Post by daxer70 »
To much complicated for me…
between T0 pins I have around 9 k ohm, the same on T1
cannot test further
