Prusa Mendel I3 need directions!
FelixP
Re: Prusa Mendel I3 need directions!
Post by FelixP »
I'm sorry, but then why was I sent both an SD card reader and an lcd display?
Alina
Post by Alina »
Dear Friend,
Sorry for this inconvenience might cause you.
Yes, you connect it with the LCD, after this you can check an SD card slot in the back of the LCD, and then you can insert SD card into the solt.
Please let me know if you still have a problem with this.
Waiting for your reply.
FelixP
Post by FelixP »
Aha! I didn't realize there was a slot there! good thing I have an adapter for the micro sd card that came with the printer.
Is there a set of directions and a download location for the firmware to allow usage of the lcd screen with the printer? if so, could you please give me the link or email me?
Alina
Post by Alina »
Dear Friend,
Attached is the firmware for you, please kindly check it.
BTY this is only the firmware for LCD12864, if you want to use this firmware with LCD2004, you can change the code as below:
Original(LCD12864):
line 399:
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
line 409:
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Change(LCD2004):
line 399:
line 409:
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Any other problem, just feel free to contact me.
Rambo Marlin.rar
(423.66 KiB) Downloaded 712 times
GiaoCodex
Post by GiaoCodex »
Were the rest of the Prusa Mendel i3 directions posted? I cant seem to find them either. If they can be mailed to me that would be good, or just point me at the PDF instructions if they are located somewhere. I havent been able to easily identify them.
I found the guide for frame assembly but havent found anything around electrornics or extruder as mentioned by the original thread owner.
FelixP
Post by FelixP »
You can find a set of directions for assembling the Wade's extruder inside the directions for the Mendel I2. they use the same extruder.
Anabatix
Post by Anabatix »
Hi, I bought this kit also.
But still the instructions are not finished.
I need to finish my build.
Where can I find the COMPLETE instructions and ELECTRICAL instructions diagram.
Same question as above posted.
Also, pic showed LCD panel... is this not part of the kit?
Regards Lee
zhangxueyou
Post by zhangxueyou »
You can find a complete building instruction at this page:
http://www.geeetech.com/wiki/index.php/ ... ction(8mm)
