Ramps 1.4 wiring
Jorzuiz
Ramps 1.4 wiring
Post by Jorzuiz »
I've been trying to assembly the Acrylic prusa i3 for a while and im having some doubts with the wiring. There is a black adapter that comes from the extruder wich i dont know where to plug (It is NOT the motor wire, is the one wich comes from the nozzle). http://www.geeetech.com/wiki/index.php/ ... _pic60.jpg
The wiring is almost complete but please send an image of the assembled ramps 1.4 so i can see if i mistaken something. At last, it is neccessary to make the connections of the heatbed if im going to print with PLA if they are neccesary please specify which are that connections. Thanks.
Admin
Re: Ramps 1.4 wiring
Post by Admin »
I will give you link where you can find how to connect every part to Ramps1.4:
http://www.geeetech.com/forum/viewtopic ... 9&start=10
And the picture below is the wiring of Extruder
Hope they will help you.
rita
Post by rita »
you can refer to the build instruction here http://www.geeetech.com/wiki/index.php/ ... side_panel
rita
Post by rita »
