Printer dead? (Acrylic Geeetech I3 pro B)
Re: Printer dead? (Acrylic Geeetech I3 pro B)
Image of switch - connections are good.
- 2015-04-13 07.29.49.jpg (600.22 KiB) Viewed 11346 times
Please contact customer service.3d Printer Noob wrote:Image of switch - connections are good.
I have the exact same problem now. A couple weeks ago i received my replacement sanguinololu, after it was determined the z axis was shot, and then put it back together with new z axis threaded rods. I fired it up, leveled the bed, and started printing. 25minutes into the print, the green led went off, then just glowed while it was plugged into the pc. Everything else stopped. There is no voltage coming off the power supply at all. It seems this printer is plagued with problems.
You said you plug your printer into pc when it's printing? Ofcourse that will stop the printing.cazuroweste wrote:I have the exact same problem now. A couple weeks ago i received my replacement sanguinololu, after it was determined the z axis was shot, and then put it back together with new z axis threaded rods. I fired it up, leveled the bed, and started printing. 25minutes into the print, the green led went off, then just glowed while it was plugged into the pc. Everything else stopped. There is no voltage coming off the power supply at all. It seems this printer is plagued with problems.
It's always plugged into the usb, that's how repetier runs and sends the code.
How about printing off line by SD card?cazuroweste wrote:It's always plugged into the usb, that's how repetier runs and sends the code.
Won't turn on at all. The power supply is dead.
Can you get 2 groups of 12V out put voltage from power supply?
No output from the power supply. Multimeter confirms it is not working.
It seems dead, if wiring is correct.cazuroweste wrote:No output from the power supply. Multimeter confirms it is not working.
