Bad Print Quality
Khilborn
Re: Bad Print Quality
Post by Khilborn »
Orest, you should really calibrate you printer using a cube first. You are trying to print a to complex object and your printer is not even calibrated correctly.
Khilborn
Post by Khilborn »
zhangxueyou wrote:The distance between nozzle and hot bed is still not low enough. No gap between the lines of first layer is the best.
I can barely get a piece of paper between the hot end and the bed. Its really snug.
zhangxueyou
Post by zhangxueyou »
Calibrate it when printing.
orest
Post by orest »
In terms of calibration. Is there a procedure that is described somewhere, in terms of what to vary and what I should get? I have not been provided one by Geeetech. Regarding the structures that I printed, I already did a cube and a box that Geeetech send me. This current piece is a calibration piece that I got from RepRap that prints several openings of different shapes. The purpose of the piece is to reveal reproducibility of shapes and to determine if there is rounding. The key point from all of the pieces that I ran is that the bottom layers are messed up and the print quality gets better near the top.
zhangxueyou
You can smear a layer of glue or spray hair sprayer on bed to let the first layer stick to it.
veritech
Post by veritech »
I finally got a print job out. after figuring out the hairspray / glue on the bed print head heights, etc.
Is there a good document on a calibration on the machine? I just purchased the Geeetech Prusa pro i3b w/ 1.75mm material and .3mm nozzle
my test print looks horrible. almost like the plastic isn't extruding fast enough. When it was printing the infill, it wasn't solid lines. more the size it should be on the ends and stringy in between
I would love to find some test print, already g-code that I could load into Repiere software to test hardware and rule out the slicer and config files.
zhangxueyou
veritech wrote:I finally got a print job out. after figuring out the hairspray / glue on the bed print head heights, etc.
We are preparing the document.
Hussain14
Post by Hussain14 »
Greetings,
Finally, when I was able to print. i got a very bad quality printing.
I used the setting that you share for Printer I3 B, ABS 1.75, nozzle 0.3 as default when buying.
the picture below is talking:
I used Temperture trying from 240 up to 255,a and 95 up to 110 for hotbed
the problem is that the filnamnet is not melting very well and not going out from the nozzle very well, and then not stucking well on the hotbed.
I tried to clean the nozzle,, but still the problem not solved.
Please help to solve this issue, because i spent alot of time trying to run the printer in good condition.
Thanx,
zhangxueyou
Hi, you can smear a layer of glue if the filament can not stick to hotbed.
And you can refer to the slicer settings at this page:
http://www.geeetech.com/forum/viewtopic ... 14&t=16366
