all axis only move in negative direction (to the home)
nima
Post by nima »
Hello
I have bought the i3c (dual extruder) Order NO:20150425133354237 Order Time:2015-04-25 13:33:54
x and y can only go home and they are not moving the opposite side, they don't even puls
z is trying to go home but it moves really hard and seems stiff, I tried to lubricate the threaded rod and the z axis nuts but did not help, for moving to the opposite side it don't even puls,
didn't try the extruders yet
zhangxueyou
Re: all axis only move in negative direction (to the home)
Post by zhangxueyou »
How do you connect the endstops? Could you please take a picture of mainboad , and different angles of printer, let me see the color of wires connected to endstops.
nima
Post by nima »
I am not home to take pictures right now, but my board is exactly the same board as is shown on the manual and I have connected the end stops the same way as it is shown in this manual step 5
http://www.geeetech.com/Documents/Acryl ... uction.pdf
pages 72, 73, 74
nima
Post by nima »
The Z axis is moving fine now, one of the rods threads is damaged and have a dent in it and that was causing the issue, I will talk with the customer service regarding that and some other broken parts later, I will avoid that part of the rod for now Until resolving the one direction movement issue,
I moved all of the end stops from their current position which are labeled as x-min, y-min, z-min to x-max, y-max, z-max and noticed that now I have movement in both direction but when I click home each axis goes to the opposite direction of end stop and obviously when it reaches the end it does not stop until I restart the printer,
also I noticed that with this configuration I have the option to move all 3 axis from the lcd while with the original configuration I only had the option to move x and y,
I moved the end stop connections back to the original configuration for now.
zhangxueyou
Endstops should be connected to X-MIN, Y-MIN,Z-MIN.
Please check if the wires are well plugged.
nima
Post by nima »
yes, as you can see in the picture they are connected properly and working, I made sure bye pressing each one while the motor was rotating and it stopped the motor.
nima
Post by nima »
also any idea why I only have movement control for x and y through the LCD ?
prepare>move axis>move 1mm>move X/Y
I don't have Move Z when the end stops are connected to z-min but I had it when I tried and conected the end stops to max!
zhangxueyou
Even after uploading the firmware I sent you, all the axes can not move normally when z endstop connected to z-min?
nima
Post by nima »
Oh I dint know that's you who emailed me the firmware as I asked for it in another topic I thought that is the same firmware I already have on my board.
I will install the firmware and update you with the result.
thanks
nima
Post by nima »
I uploaded the firmware and nothing was changed and the movement were the same,
I changed the following parameters in the file configuration.h from false to true
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
now the x and y axis are moving fine but I still don't have the option to move the z axis from the display!
