I just received a black acrylic i3 prusa with Sanguinololu. I have wired it up, it powers on with fans running & a red light on the board but the LCD panel doesn't display at all.
I have added the specialized firmware, added the USB drivers, & it is seen by Repetier-Host.
In Repetier-Host there is no measurement of temperature for the bed or extruder + there is no manual control over the motors, etc. No movement at all.
Any idea as to what is wrong? Possibly mis-wired somewhere?
Thanks.
I3 ACRYLIC W/ SANGUINOLOLU ISSUES
zhangxueyou
Re: I3 ACRYLIC W/ SANGUINOLOLU ISSUES
How about swapping the connection of 2 cables behind the LCD screen?
thegooglemoogle
I will try the LCD screen swap but what about the lack of movement in the motors + no heat being generated by the Extruder & Bed?
Thanks.
Thanks.
thegooglemoogle
I managed to get the LCD screen to display & the X & Y axes to home. My going down is binding up on one side so I need to make some physical adjustments.
Thanks.
Thanks.
thegooglemoogle
Hi again,
I am able to home X & Y axes but the 2 Z motors rotate in opposite directions with one turning left & the other right. How do I remedy this?
Thanks.
Thanks.
zhangxueyou
Normally, when you want the z axis move up, the motor rotate clockwise, so you should reverse the connection of one of the z motors.
thegooglemoogle
Thanks. I reversed the black connector & now it moves fine.
