Printer dead? (Acrylic Geeetech I3 pro B)
cazuroweste
Re: Printer dead? (Acrylic Geeetech I3 pro B)
Post by cazuroweste »
Yes, the wiring is correct. I sent all the pictures of it when we diagnosed the sanguinololu board was bad. The power supply worked long enough for me to level the bed, and start printing part of a print, then just up and died.
zhangxueyou
Post by zhangxueyou »
cazuroweste wrote:Yes, the wiring is correct. I sent all the pictures of it when we diagnosed the sanguinololu board was bad. The power supply worked long enough for me to level the bed, and start printing part of a print, then just up and died.
If your computer can recognize sanguinololu when you connect it to computer without power supply, the Sanguinololu is fine.
cazuroweste
I know that. I said that the sanguinololu was fine after it was replaced. The power supply is what went bad and needs to be replaced.
zhangxueyou
cazuroweste wrote:I know that. I said that the sanguinololu was fine after it was replaced. The power supply is what went bad and needs to be replaced.
Yes.
cazuroweste
What do we need to do to get a replacement going?
zhangxueyou
cazuroweste wrote:What do we need to do to get a replacement going?
Contact the customer service.
