LCD Panel adapter for RAMPS-FD Not Work LCD 12864
saviothecnic
Post by saviothecnic »
Good Day
I bought your Ramps-FD adapter and LCD
I'm trying with Ramps-FD 12864 RepRap Arduino Two and LCD Full Graphic
But it does not work Beep Fixed and LCD Illuminated but without graphics as in photo
I know the mapping pin connectors EXP1 EXP2 so as to check if the firmware is correct Marlin.
thanks
zhangxueyou
Re: LCD Panel adapter for RAMPS-FD Not Work LCD 12864
Post by zhangxueyou »
Hi, the picture you attach is invisible.
saviothecnic
I enclose picture for those who do not show
zhangxueyou
Which board works with Ramps-FD? Mega2560 or Due?
saviothecnic
Using Arduino TWO
I have a 1.4 Ramps with Arduino Mega 2560 and this LCD module works Well
I took Ramps-FD to use Arduino Two 32Bit
zhangxueyou
Could you please take a photo of Arduino TWO?
zhangxueyou
Is it Arduino DUE?
saviothecnic
It is Arduino DUE sorry use google translator
zhangxueyou
Maybe it is firmware issue.
saviothecnic
you can
This is why I asked that mapping PIN
that has your card and its adapter FD-Ramps
connectors EXP1 and EXP2 so I can make sure everything OK
I tried both with http://marlinkimbra.it/
That with https://github.com/Wurstnase/Marlin4Due
