My slicer settings
zhangxueyou
My slicer settings
Post by zhangxueyou »
I use Geeetech Prusa i3B, with 1.75mm filament and 0.3mm diameter. Slicer software is Slic3r. Attachment is my slicer settings, I got good print with these settings, you can try.
Actually, anyone who uses different kinds of printer, or the same printer with different filament diameter or nozzle diameter, can also refer to this setting. But you have to change some parameters in slic3r, including "filament diameter", "nozzle diameter", "first layer height"(it is as same as nozzle diameter), "other layers height"(I suggest lower than first layer for 0.05-0.1mm).
slicer settings(1.75mm-0.3mm).zip
(388.83 KiB) Downloaded 2291 times
zhangxueyou
Re: My slicer settings
You can also load the configuration file directly.
import slicer setting 1.png (46.16 KiB) Viewed 45114 times
Open slic3r in Repetier Host:
import slicer setting 2.png (52.58 KiB) Viewed 45114 times
import slicer setting 3.png (87.36 KiB) Viewed 45114 times
slicer config.zip
(1.27 KiB) Downloaded 1923 times
johnz
Post by johnz »
What speed on the feed rate and flow rate??
zhangxueyou
johnz wrote:What speed on the feed rate and flow rate??
1 or 1.1 maybe.
johnz
Post by johnz »
Ok how about on the Repetier v1.0.6
zhangxueyou
johnz wrote:Ok how about on the Repetier v1.0.6
I use Repetier1.0.6 exactly. And I use the slicer settings as the attachment above, and it prints fine.
thhale
Post by thhale »
Thanks for sharing.
gpau
Post by gpau »
where I find the slicer setting for mac Ios?
Thank you
Cup
Post by Cup »
@gpau
So the Mac version doesn't recoganize the .ini format file?
gpau
Post by gpau »
@cup
ok,
I can get it for windows
thanks
