overheating issues
gemors
overheating issues
Post by gemors »
G'day all,
Got my printer about 4 weeks ago, took me a week to build (very little spare time), been printing a few things then yesterday, I got this very strong burned plastic smell and the printer just stopped. Now if I plug the usb cable in the LCS will show the normal information and it's readable, but when I put the main power on then I cannot reead the lcd pannel all the little 'blocks' are active. I can connect to the printer bur no controls or commands make it through.
Please Please help me
zhangxueyou
Re: overheating issues
Post by zhangxueyou »
Hello, what's is your printer type and mainboard type? Where is the smell from?
gemors
Post by gemors »
Hi mate,
I believe it's a 'Sanguinololu V1.3a A4988', you can see in the attached pic what has happened.
Sanguinololu V1_3a A4988.jpg (59.81 KiB) Viewed 12447 times
regards
J
gemors
Post by gemors »
It's a Sanguinololu V1_3a A4988
zhangxueyou
Hi, can you tell me what's the resistance of hot bed? How did you mount the mainboard to acrylic plate?
gemors
Post by gemors »
The hotbed was pre soldered by geeetech and hooked into the blue connectors, the ones that melted down in the picture.
I cannot measure the resistance as the board is pretty much dead
This should not happen...
zhangxueyou
What is your printer type?
gemors
Post by gemors »
It's GEEEtech-PI3A
cheers
J
gemors
Post by gemors »
Missed your one question,
The main-board is mounted with spacers to the acrylic plate.
regards
J
zhangxueyou
What is the mounting direction of mainboard?
Disconnect the wires of hot bed, you can test the resistance of hotbed as the picture:
test hot bed resistance1.png (395.11 KiB) Viewed 12434 times
