X min and z min problems
x306xcptnkirk
Post by x306xcptnkirk »
New board, steppers and when I autohome the x goes the correct way but the y and z turn the opposite way and go towards the max. How do I reverse the motor direction?
zhangxueyou
Re: X min and z min problems
Post by zhangxueyou »
What is the board type? Can you reverse the connection of y and z motors? Is the endstop connected correctly?
x306xcptnkirk
Sorry about that it's a gt2560. Endstops are correct. When the x and y cables are switched. The x goes the correct way but the y still goes the opposite way
x306xcptnkirk
Switching y and z does yeild the correct direction though. What should I do to get the printer to work with them plugged into the correct sockets?
zhangxueyou
Oh, the motors can only be connected to gt2560 in one direction.
Maybe it's firmware issue, what is your printer type? Let me send you a correct firmware.
x306xcptnkirk
It is a i3c. How would I upload the firmware as well?
x306xcptnkirk
please send the firmware as well as instructions on how to burn the firmware to the gt2560 i3c. Do you email the firmware or post it here? Also should i use arduino 1.0.1 or 1.6.5 software on windows?
zhangxueyou
We will send the firmware to your email, you can refer to this page to upload:
zhangxueyou
I suggest you use Arduino1.0.1 to upload the firmware:
http://arduino.googlecode.com/files/ard ... indows.zip
x306xcptnkirk
Okay new firmware uploaded and it works correctly now. But when I start a print in repertoire it only preheats bed before starting print, but the manual preheating extruded works, is there a setting I can change?
