Same problems with manual in fitting ,but is okey..
my problem is the extractor motor... don't work... as normal, in normal place (don't make any move)
I Have replace the a4988 from extruder with the x axis ... nothing
I have replase the cabels from extruder to X axis... the motor ticks .. work.. (is not the motor)
BUT don't work in the right place..
I have tested with build in control>prepare> move axis > 1mm > extruder... NOPE (over 180 degrees)
and i have try to print... the system works perfect.. print .. but with INVISIBLE color.. the extrude motor don't wont to work..
Any HELP ??? ... no fun at all, i have pay 500€ (in total with clearance) and i don't have printer..
