Z-axis unreliable zeroing
zhangxueyou
Re: Z-axis unreliable zeroing
According to the pictures, the Acrylic is smaller than hot bed, the distance between the center of hole is about 20.87cm. We are so sorry about that. Could you please contact the seller your issues.
TheDreamMaster
I have contacted the seller. What should I do now? Ask for a replacement with properly drilled holes that match?
zhangxueyou
Sorry, I can't tell you what to do because it's not my job. The seller will address the issue for you.
x306xcptnkirk
It's probably your extruder head holder warping. It's an issue with these as they are printed in pla and warp in the heat. Change out the holder and you may be okay.
TheDreamMaster
The problem exists when the extruder is not being heated, just the bed. So, I don't think it is a problem with the extruder holder.x306xcptnkirk wrote:It's probably your extruder head holder warping. It's an issue with these as they are printed in pla and warp in the heat. Change out the holder and you may be okay.
Thanks though.
