X,Y, & Z axis motors do not move in manual control
VIJAY
Post by VIJAY »
LCD Display
LCD Display
Assembled Printer
Assembled Printer
I have now completed the assembly of the Geeetech I3 Pro B.
This has only GT2560 Control Board. I have downloaded the Repetier-Host GEEETech V0.09D
program. I am only able to make the motors move to the home position from the LCD display (Auto home).
I am not able to control the motors manually from the manual control in the program.
The display shows extruder at 0 degree, the HOT BED at 24 degrees. Err: MINTEMP. FR: 100%.
Please can you explain what are the issues at present and what needs to be done to resolve these issues.
Vijay
zhangxueyou
Re: X,Y, & Z axis motors do not move in manual control
Post by zhangxueyou »
When LCD displays "0/0", the corresponding thermistor is not well connected to mainboard, or it is plug to the wrong slot.
"Err: min temp" means extruder thermistor is not well connected.
"Err: min bed temp" means hot bed thermistor is not well connected.
You must let all the axes auto home if you want to control x, y, z separately.
Could you please take a picture of your mainboard with wiring, let me check for you.
VIJAY
Post by VIJAY »
Hi Zhang,
Thanks for the response, forwarding the wiring pictures. I have removed
the LCD and SD card cable for better view.
Vijay
Motors & endstop wiring
Motors & endstop wiring.JPG (71.32 KiB) Viewed 8083 times
Extruder, Hotbed thermistor wiring
Extruder, Hotbed Thermistor wiring.JPG (53.34 KiB) Viewed 8083 times
Extruder & hotbed wiring
Extruder & Hotbed wiring.JPG (58.38 KiB) Viewed 8083 times
Main Board wiring
Main Board wiring
Main Board Wiring.JPG (76.46 KiB) Viewed 8083 times
Sherry
Post by Sherry »
hi,according to your describe, the motor do not turn because it could not read the temperature correctly.please replug the thermistor wire and tighten it.
