Hi all experts
My G2s able to move arm in all axis smoothly in medium speed but as G28 & G29 running in fast speed, Y-Motor or Timing belt start skipping or stuck ( (make aweful sound)) in fast or sudden moment especially G28 & G29 and cause G2 s loses its coordination & could not do proper Auto-leveling. Please give some advise if belt-tension or some other issue has causing problem. Please assist.
Thanks in advance
G2 belt tension on XYZ motor
fotomickey
Re: G2 belt tension on XYZ motor
hi,please reduce the travel feed rate.more information,please refer to following link.fotomickey wrote:Hi all experts
Thanks in advance
http://www.geeetech.com/wiki/index.php/ ... _preparing
- QQ图片20150728152951.png (129.8 KiB) Viewed 5926 times
fotomickey
Thanks Eric, problem solved
