Prusa I3 Pro B
Prusa I3 Pro B
Following http://www.soonwell.com/ebay_file/App_pic/i35_21 Im on step 7.2, assembling the X-Axis Rods and ends. The screw locking fender that is supposed to be screwed down tight to the smooth rod has no set screws. Are there supposed to be some, am I supposed to use something else, or are they not supposed to be screwed down tight?
Re: Prusa I3 Pro B
hi,the smooh rod should be tighten up with M3*16 screw.please look at the picture.Warfey wrote:Following http://www.soonwell.com/ebay_file/App_pic/i35_21 Im on step 7.2, assembling the X-Axis Rods and ends. The screw locking fender that is supposed to be screwed down tight to the smooth rod has no set screws. Are there supposed to be some, am I supposed to use something else, or are they not supposed to be screwed down tight?
- QQ图片20150804104127.png (72.67 KiB) Viewed 12060 times
Re: Prusa I3 Pro B
Im beyond that point. Im talking about the screw locking ring, part 19 in the booklet that came with the printer.
Re: Prusa I3 Pro B
is this part?yeah,it has a set screw,it is matched with screw locking ring.it has been assembe well before leaving factory.please check whether it drop out.Warfey wrote:Im beyond that point. Im talking about the screw locking ring, part 19 in the booklet that came with the printer.
- QQ图片20150804172218.png (197 KiB) Viewed 12047 times
Re: Prusa I3 Pro B
Good news is, I got my answer and thanks for that. Bad news is, they didnt come with the locking screw and I havent seen any, either in the bag or anywhere else that will fit in that slot. Any ideas?
Re: Prusa I3 Pro B
Maybe if you are lucky enough,you can find a same one in your garage
Or you can contact the customer service to have a new one .
Re: Prusa I3 Pro B
I was able to find a set at Lowes. Thanks for the help guys
