Delta GS2 hot end fan question
rxn123talon
Post by rxn123talon »
Greetings,
I have setup a Delta GS2 and do not see the fan on the hot end running. Does this fan normally run all the time? Is there a way to test this fan works before I try my first print?
rxn123talon
Re: Delta GS2 hot end fan question
The fan is connected per instructions for G2S -- Connect fan for hot end at FAN-PWM.
Sherry
Post by Sherry »
rxn123talon wrote:The fan is connected per instructions for G2S -- Connect fan for hot end at FAN-PWM.
hi,pwm fan is controled by g-code.
