Almost finishing to assembly the printer. I have some details:
1) There is an interference for the free movement of the nozzles with the clips installed to hold the cristal in the front and in the back, so this reduce the printing space. Mostly the clips installed in the back since it reduce about 5cm of the print area ->
2) Is there any instruction of how to level the nozzles? Is it necessary to dissasembly the printer head?
3) Is there any way to know the nozzle size? In the nozzle it is written "2-0" as shown in the picture above.
Geeetech i3 pro C dual extruder 3D - Assembly Final details
Re: Geeetech i3 pro C dual extruder 3D - Assembly Final deta
As problem 1and 2,you can adjust the nut to get the height you want ,and your problem will be solved!
- QQ截图20150814095141.jpg (420.48 KiB) Viewed 5361 times
