Hi to all!
I'm new on this, I follow the instruction and the have all build and connected, but the endstop are no connected because I don't kwon where to connect them, if need to be connected on the x min or x max; y min or ymax or zmin/zmax.
thanks for any help, also I read about firmware and arduino, my board is GT2560 white, what I need to do next after fix limit switch issue.
Thanks for any help!
I3 proB 3D printer MK8 Extruder with GT2560
Re: I3 proB 3D printer MK8 Extruder with GT2560
Hi,you can connect it as follows:
- GT2560 connection.jpg (762.29 KiB) Viewed 5361 times
Thanks for your respond!
I was reading and almost fix all my issues, but a new issue show up, when printing a test figure, the abs doesn't stick to bed, I put hair spray on it but didn't work, I lower the z end stop to paper diameter .1mm and didn't work, I'm uploading a video so you guys can help me, thanks for any help!
