Delta Rostock mini G2s Extruder drives Axial motors
brent_jackson
Post by brent_jackson »
On my system I have completed initial build and calibration but have yet to be able to print anything.
What I observe is that, using the Repetier-Host interface, manual commands to advance extruders will occasionally cause X/Y/Z axial stepper motors to activate, driving upwards. If the system is in home position, the end stop signals are ignored and I have to do an emergency stop.
Repeatability is not 100%, but here are steps I have used:
  1. Connect
  2. Select Manual Control Tab...
  3. Home system
  4. Click Heat Extruder
  5. Select Extruder 2
  6. Click Heat Extruder
  7. Wait for extruders to heat to 200C
  8. Select Extruder 1
  9. Click down arrow by Extrude
  10. Select Extruder 2
  11. Click down arrow by Extrude
  12. observe axial motors driving up with shaking click
  13. Click Emergency Stop
Using G2S firmware downloaded 15aug2015. Internal file dates are 16jul2015.
Mark
Re: Delta Rostock mini G2s Extruder drives Axial motors
Post by Mark »
If your wires were correct connected, might it be the firmware's problem?
JHill42
Post by JHill42 »
Hello Brent,
I had a similar problem - it seems to behave badly shaking its way to the top and ignoring the endstops. I purchased another GT2560 and replacement A4988 (stepper motor boards), but the problem remained. It didn't do it all the time, but it sometimes took 10-20 power cycles to get it working OK - after it was OK, it could run for many hours without troubles.
I finally narrowed it down to a couple of G-code command that seem to cause issues. The commands are G1 Z15 Fxxxx (where xxxx is a travel rate) and G92 E0. When using the GeeeTech version of Repetier (an older version from the instructions), I would run the slicer and edit the G-codes to remove the problem commands. I also found that adding a G28 (home) right before printing helped with positioning. Using the newer versions of Repetier - I've switched to the Curra slicer and just comment out the G1 Z15 Fxxxx line in the G-code setup. I also found that I needed to add a conditional tool select (T0 or T1), to select the extruder - this also goes in the startup G-codes section.
I think there must be some bug in the firmware that causes this, but I haven't looked into it.
I hope this helps,
Jeff
brent_jackson
Thank you both Mark and Jeff for your responses.
I imagine that if the motors were incorrectly connected, then I would not be able to home the system and extrusion would not sometimes work.
I have since updated to the August 24 version of the firmware with no perceivable difference in behavior.
I might have to try power cycling to see if that fixes the issue.
I am using the Geetech Repetier Host app V0.90D... from what Jeff writes, perhaps that is not the best choice. I'm open to suggestions.
With respect to the G-code commands that seem to cause issues, it seems pretty daunting if I have to manually edit the code for each sliced object. At this point I'm only trying to manually extrude and have not yet attempted to print a single piece. When I click the button to manually extrude 10mm on Extruder 1, I see the following commands sent to the printer:
G91 *53
G1 E10 F1000 *62
G90 *54
None of these seem to be the G-codes you have identified, but perhaps it is a similar problem.
As I write this, extruder 1 now seems starting to behave as desired, but I expect the wrong behavior to return after reboot.
Just FYI, I also have issues with auto leveling similar to the Autolevelling destruction G2S thread.
Mark
Post by Mark »
I know this one behavior: print with extruder 1 is OK, and if you manually control extruder 2 then the other axis will move up and extruder 2 have no response.
This is a bug and we'll fix it asap!
JHill42
Post by JHill42 »
Hello Brent,
I'm pretty sure my problem was not wiring, but a firmware issue. I jammed up the first extruder pretty good (was able to unclog later) and started using the second one. With multiple versions of Repetier I ran into the problem - so I don't think it has anything to do with the version used. It just seems to be certain codes that cause problems. I used the G-code editor to comment out lines until it worked OK. I now use the newer version of Repetier and the Curra - this has a default job G-code section which I edited to remove the G1 Z15 Fxxxx line and added the conditional tool select (T0 or T1) - you won't need to do this each time. There may be other codes that cause issues, but I haven't run into them. For what it is worth, my manual extrudes do work, but I think I set to a lower feed rate (something like 50 or 25).
Mark - when you get a fix, please let me know - I'd love to give it a try...
Thanks,
Jeff
flamtap
Post by flamtap »
Mark wrote:I know this one behavior: print with extruder 1 is OK, and if you manually control extruder 2 then the other axis will move up and extruder 2 have no response.
I have been printing with one extruder successfully for a few weeks. Tonight I started working on getting the 2nd extruder running, and I am seeing this exact problem.
When I go to manually extrude using repetier, all 3 axes start moving upward. Please provide a fix ASAP!
flamtap
Mark
Post by Mark »
We are testing the latest firmware now, it won't take long to fix the problem, plz wait with patience, tks!
rickr
Post by rickr »
HI Flamtap,
Are you saying that after you "#defined 2 extruders" in your firmware, then you started having the problems we have all experienced?
Cheers, Rick
flamtap
Post by flamtap »
Rick,
Yes, but defining 2 extruders does not seem to trigger the problem. It only seems to happen when the 2nd extruder is told to actually extrude something.
I can still print "normally" using just the first extruder, even with 2 defined.
flamtap
