Is there a offset setting for the dual heads ...
The test print, prints two different parts where it should be one. (that would be the test print from you guys)
What is the offset setting....how and where do I go to get it to talk to the Prusa Pro firmware
I have tried setting it in slicer using -12.5 and +12.5 and there are no results....still a mess....tried 30mm on just the 2nd extruder ...no results still a mess
is there some secret to this...?
this is after my dual head bracket melted of the printer from the heat and weight....I have since replaced the 3d printed original part with metal...
Extruder alignment
Re: Extruder alignment
After you change the extruder offset , have you select the corresponding extruder configuration and reslice the object?
- QQ截图20150826154837.jpg (82.43 KiB) Viewed 8964 times
Here are my current experimental extruder settings
i have noticed no difference in implementing it...on printing. I make the settings and have even tried saving and rebooting...nothing..no change...so, I think...once again, software not talking to hardware..? who knows...only the programmer..
- image3.JPG (84.8 KiB) Viewed 8953 times
- image2.JPG (99.3 KiB) Viewed 8953 times
- image1.JPG (92.84 KiB) Viewed 8953 times
I guess your moderators don't like my posts ...well I must admit they don't show your product at its best...
Then you can reburn your firmware to verify it .
As you can see the alignment setting is not being accepted...this is your test program for dual heads abs...it didn't even go through my slicer...came straight from you guys...
is there firmware upgrades to resolve this?
And what do you mean by "reburning firmware"?
and exactly how and when is that going to happen...
- image2.JPG (101.05 KiB) Viewed 8939 times
