I have no working endstops
jlgale
Post by jlgale »
Hello everyone, I have a odd issue. I dont think it is a firmware but I am not sure where the problem is coming from. I dont have any endstops working. I am using the Acrylic Geeetech I3 pro 3D printer DIY kit. I have not been able to get the endstops to ever work on it, I reloaded the firmware to make sure that wasnt the issue but they still do not work. I am have the gt2560 board and I have tried to switch the plugs to the endstop max socket but still nothing. could the issue possible be my board? any suggestions is greatly appreciated .
the firmware i am using is on this forum page.
http://www.geeetech.com/forum/viewtopic ... 20&t=16782
jlgale
Re: I have no working endstops
Post by jlgale »
for anyone that may be having the same issue, I had a bad board. I purchased a new one and everything works fine.
Mark
Post by Mark »
All the endstops not working ?
jlgale
Post by jlgale »
yes, all my end stops were not working. regardless of the firmware and replacement end stops, the board would not recognize them. a new board fixed it. the previous board was bad from the beginning. I was never able to get one print off of it.
stevemcl
Post by stevemcl »
How do you test the endstops, if you press the endstop down should that stop the movement?
thanks,
steve
Mark
Post by Mark »
Yes, press the endstop when homing the motor will stop and regard the position as zero coordinates.
