printing bended bridge
steven
Post by steven »
hello,
say i would like to print a bended bridge (picture will follow).
is it possible to do it without support and manipulate overlap layers with extrusion width?? so every layer overlaps the other so i can print in a slightly angel and make a bow
thanks
Mark
Re: printing bended bridge
Post by Mark »
Why not lay it down and you'll need no support layers.
steven
Post by steven »
yes i know in this simple picture it is the correct solution but in my object i want to print is not possible.
this is just schematic picture.
i wonder if it was possible to print every layer with an overlap of say 50%
thanks
Mark
Post by Mark »
it's hard to say, you can try it :D
dogma
Post by dogma »
How would you add support if you did need it? Sketch up?
Mark
Post by Mark »
you can add it here:
dogma
Post by dogma »
What for example would you put for the perimeters?
Mark
Post by Mark »
I can give you my settings for my G2S pro, see the attachment.
111111config.zip
(1.66 KiB) Downloaded 434 times
