OK down to wire rebuilt again new parts ready to finailize
jamest
Post by jamest »
Ok got new hot ends... THANK YOU. with pla ring.. need to order pro kit.lol it is going to cost more than a new G2s pro...lol ok g29 issue.. And if I try to print it hits, and as it moves starts to raise & air print. nothing sticks to bed 2nd extruder scraps up pla. ...taffy puller. need more help on settings. AM I close? lol advise plz missing some things in my settings but what . more info needed on auto homing easy setup...ok how to " easy setup" lol
need cost for g2s pro kit to upgrade my G2s plz I want to order it asap. g29 keeps cracking ring.
Mark
Re: OK down to wire rebuilt again new parts ready to finaili
Post by Mark »
usually if your homing is OK, and you can control your axis through repetier host, then you can print. is your homing well or not?
jamest
Post by jamest »
I don`t think so, I can set g codes g28..but g29 slams , if I do the homing I get 200 tried to set to 197.7 .... hit bed then as print went it rose up from bed to air print then retuned to hit bed. SO it thinks the bed is curved? convex center level goes higher to the sides. also nozzle 2 gets in the way.. learning curve or printer not as supported as it needs to be?
jamest
Post by jamest »
Ok now I can get G29 code working but still air printing..lol pla not sticking to bed ect...
ok next issue. lol
jamest
Post by jamest »
I want a discount on the pro kit for the metal parts to my G2s ...lol so contact me asap..... sent emails. holiday ok. but soon ok. need to get this up & running soon so I can print some things b-4xmas .lol :roll: :roll:
Mark
Post by Mark »
you can contact the seller to talk about this.
As for the air printing, can you send a video to see that?
jamest
Post by jamest »
what video format can I use ? mp4 , wma mp3 I get a message it is not allowed?
Mark
Post by Mark »
you can send a link of youtobe here.
Mark
Post by Mark »
Your probe was assembled in the wrong direction, and before start G29 you should home the printer first.
You can refer to the link here to check the status of the G2S: http://www.geeetech.com/forum/viewtopic ... 13&t=17042
