G2S Pro Stepper disable problem
coop
Post by coop »
I have just built the G2S Pro Rostock delta printer. I have been able to tune it enough to get reasonable prints from it. The problem I seem to be having is that when the last G-Code command gets sent from Repetier-Host software the stepper motors are all disabled which causes the hot end to fall from the Home position down onto the part if I am not right there to catch it.
I am running Repetier-Host 1.5.6 with Slic3r 1.2.9.
Things that I have tried so far.
I removed the M84 command from the End G-Code in Slic3r.
I changed the Default_Stepper_Time from 60 to 0 in Marlin Configuration_adv.h.
I would like to keep the X,Y and Z steppers Enabled to prevent the hot end from falling.
Has anyone else seen this problem? What was your fix?
Thank you
David Cooper
Mark
Re: G2S Pro Stepper disable problem
Post by Mark »
you need to delete the code here:
And do not select the option here:
coop
Post by coop »
Mark:
Thank you. The last item - Unchecking the Disable Motors after Job/Kill was the one that fixed my problem. I don't know how I missed that one!
Coop
lar3ry
Post by lar3ry »
I hope this is not considered hijacking a thread, but I have been trying to stop the print head from crashing to the bed after a G28 command. I had already set the printer settings as shown in this thread, which does solve the problem of the head dropping after a job finishes. However, it still crashes after clicking the HOME button in Repetier.
I wrote a small script for one of the buttons, which issued a G28, followed by M84 S0, but I still hit that Home button asa a matter of habit (I run two different printers with that Repetier).
So, I have come up with what looks like a fix that works for me, but I would like to run it by the experts here to see if it might have some other effects that are not so good.
In Marlin_main.cpp, at the end of gcode_G28(), I placed a line that performs the same function as an M84 S0, as follows...
endstops_hit_on_purpose(); // clear endstop hit flags
stepper_inactive_time = 0; // larry mod to perform M84 after home
I figured that I never want the head in the MAX Z position without locking it.
I even designed and printed a set of carriage hangers so I can leave the head high off the bed when I power it down (Thingiverse, Thing number 1326881).
G2Ser
Post by G2Ser »
This still doesn't work for me having completed all the following
I think the end-code should be HOME all axis but not home x-axis. So you should modify the G28 X0 to G28 in the end G-code.
