voice recogniton module
				dinamovera
Hello everyone here! I just got the voice recognition module from amazon, It's from geeetech, But it does not work for me, I already set up the AccessPort software, but when I try to send AA11 nothing happens in terminal and red light module never stops to blink, does anyone can help me please?
						- techsupport
 - Site Admin
Re: voice recogniton module
I was testing your phenomenon, Back to you later.
Email: forum@geeetech.com
				dinamovera
I fixed the debugger issue, now I cannot record anything, always I try to say something after START message and  I always get No Voice, Does anyone knows why?
						- techsupport
 - Site Admin
You can choose a quiet environment Or choose connected microphones for voice recording.
				dinamovera
I already did it, I'm in a really quite environment, and I test with differents mics. Nothing happens, I always get "no voice"
				dinamovera
Yes I did it, nothig happens, I tried differents microphones, a really quite environment, nothing happens, I alway get "No Voice"
						- techsupport
 - Site Admin
I tried the recording ,It can show success
START
AGAIN
START
Different
START
AGAIN
START
AGAIN
START
Finish one
you try to plug USB and Open the AccessPort application again.
							START
AGAIN
START
Different
START
AGAIN
START
AGAIN
START
Finish one
Use a different mic and connect it to the VOC/GND terminals on the board  The mic jack provided is not good at all.
dinamovera wrote:I fixed the debugger issue, now I cannot record anything, always I try to say something after START message and I always get No Voice, Does anyone knows why?
hey, i am also facing the same problem, nothing has happened after sending AA 11 through access port. How did u debug that? URGENT
				alberthandsome
 - Contact:
I'm happy to have someone to troubleshoot code for that module !
Right now I have a library autodetecting and setting parameters to the module, and performing "SI" recognition correctly ("Speaker Independant" words, without need of training). SAS Training
  |  Android Training
I am a bit disapointed by the SI part, you sometimes need a little tuning to make it work. The default settings are not bad. However I get a lot of "false positives". For an example, if I select SI wordset 0 (only the word "robot"), whatever I say is pretty much recognized as "robot". However for the other groups it works not too bad. If I tune the recoginition engine to "tighter", I get less false positives for my own voice (french or english), however, more for my wife's. SharePoint Training
But the thing is not too bad considering the noisy home environnement I work within (children...) R Programming Training
I should have a full beta driver available by next week end. If you want to test some snapshot, just let me know. About your hardware problem, just get rid of the transistors D2 and D3 on the "arduino shield" (you are not concerned if you are using the module directly....) SQL Training
