Need someone to email Pulley STI
Lloyd
Post by Lloyd »
Some of the parts of my new Prusa i3 Pro C were made too tight. I can download the sti files for most of the parts from thingiverse.com. But the U-shaped tension pulley housing is not there. The round bearing holder is there. But not the U-shaped holder that the belt slides though. Can someone email me an STI file of it?
hayeslloyd@gmail.com
Mark
Re: Need someone to email Pulley STI
Post by Mark »
Lloyd
Post by Lloyd »
Thank you
Lloyd
Post by Lloyd »
The file that I was looking for was not in the RAR package. However, I am pretty sure that I can make the item that I was looking for.
Mark
Post by Mark »
which one? could you post a picture here?
Lloyd
Post by Lloyd »
Sorry for not getting back here. Thank everyone for the links to the files.
I downloaded the files that I needed from here. Some of the printed parts which came with the printer had not been made to spec properly, resulting in other parts not working properly. (The X-Axis tension pulley was frozen using the original pulley. Also the Carriage was not hitting the endstop properly, nor did the bearings fit into it without breaking it.) I was able to get them re-made, and also designed a couple of new STL files which worked.
One part that I redesigned was after I noticed that the duel head carriage was not hitting the X-Axis endstop properly on my duel head printer. The handle from one of the extruders was hitting a threaded rod 1st. I did a crude redesign of it so that it hits the endstop better. That file is on thingiverse.com.
