Problem
Kire
Problem
Post by Kire »
Hello there, I have problems with the software, I have contact between the printer and the computer. but when I shall warm the bed and and extruder happens absolutely nothing. even when I try to move z, x, y axis, nothing happens. I have also updated with the latest firmware
someone else who had such experiences?
Have a nice day
Mark
Re: Problem
Post by Mark »
what's your printer type ? and have you checked the PSU output? is it 12V? and the led lights on the board, do they all come on?
Kire
Re: Problem
Post by Kire »
it is a geeetech Prusa I3 . 12v comes from the psu. all the backlighting works well
all started when I shorted the x-axis endstop and burned the control board. provided an nyt control shortly after I instal the new control cards work out just the z-axis in one direction after it stopped all work. it is possible to update e Firmware and connect with the printer, but when I want to warm the bed, and the extruder and move z, x, y axis happens absolutely nothing.
Mark
Re: Problem
Post by Mark »
According to what you said, PSU has 12V output, led lights all come on, with a new GT2560 and still not working? It's wierd...so where did you get the firmware? You can try to download this one here:
And when you heat up the bed and extrude, does the LED light under the bed and extruder connectors come on? check this link here:
http://www.geeetech.com/forum/viewtopic ... 13&t=17039
