Auto Leveling Delta G2s Pro
Roadracers
Post by Roadracers »
Having an issue with setting up the auto level of the Delta Mini G2s Pro.
The probe hits the hotbed at 1.3, but the z axis hits 0.0 before the end stop clicks. Any ideas for me? Am I doing this step wrong?
Mark
Re: Auto Leveling Delta G2s Pro
Post by Mark »
is your probe lower than the nozzle? and did you set the correct Z probe offset in the firmware? you ca leave the X and Y offset as default and just change the Z one:
#define X_PROBE_OFFSET_FROM_EXTRUDER -19
#define Y_PROBE_OFFSET_FROM_EXTRUDER -11
#define Z_PROBE_OFFSET_FROM_EXTRUDER -1.2
Roadracers
I did, but it doesn't do anything since the endstop doesn't activate. The hotend hits the warming plate before the endstop clicks.
Mark
Post by Mark »
Is your probe too short or something? I think you have two methods to correct this:
1. heat up the nozzle to about 200 degrees and unscrew the upper nut of the threaded tube to screw up the hotend a little to make sure the probe activate before the nozzle hit the bed;
2. clamp a stick or something on the end of the probe to to make it a little long more.
