Aluminum Prusa I3 Sanguinololu - Firmware/Software Questions
DAT
Post by DAT »
Just getting my head around all this info: so far I have concluded that the Arduino IDE is the editor/compiler for the Marlin Firmware definition file which when compiled by Arduino becomes the machine code/firmware file that is uploaded into the Sanguino board ? (the Sanquino firmware is just a subset of the Marlin code).
Now having installed the Arduino and Marlin software and I believe the Sanguino board files into the Arduino Hardware folder to enable Sanguino to show up in the Tools menu, I only find three board types and can only compile without errors using one of them, the Sanguino W/ATmega1284p 16Mhz, so I am hoping that this is the correct board selection, can you confirm ?
Sherry
Re: Aluminum Prusa I3 Sanguinololu - Firmware/Software Quest
Post by Sherry »
DAT wrote:Hi,
hi.it's right. more information please refer to the post.
DAT
Post by DAT »
Thanks, I found the information by looking at the markings on the Chip mounted on the control board ;)
