Cheap extrusion feeding
noneoneisb
Post by noneoneisb »
Hi!
Can someone help to fix this problems? I'm printing PLA
I already tried (and failed) with:
1- set extruded rate fro 100% to 120% (but nothing change)
2- remove retraction
3- testing different temperatures in noozle and bed
It seems a low feedrate ratio but I'm not sure.
Thank you for help :roll:
Sherry
Re: Cheap extrusion feeding
Post by Sherry »
hi, how much diameter of filament, nozzle do you use? did you set them correctly in repetier host and slice3r?
noneoneisb
1.75 filament diameter, 0.30 noozle.
Yes, i checked all software settings, and they are still correct and feeder driver too.
Sherry
Post by Sherry »
noneoneisb wrote:1.75 filament diameter, 0.30 noozle.
please send me the slice configration. btw, what's the printer type?
