LCD screen button Will Not Scroll
Demech
Re: LCD screen button Will Not Scroll
Post by Demech »
Hi everybody!
I am facing the same issue with my printer!
Can i have a solution or a correct firmware because my encoder is not scrolling even if the push button works.
Thank you in advance.
Mark
Post by Mark »
might check the pads on the LCD panel, see if there's bad soldering or short out there:
or the pins of the mainchip, related to the SD card and knob function here:
LCD 2004 pin SD card.jpg (427.47 KiB) Viewed 8209 times
LCD 2004 pin LCD.jpg (609.02 KiB) Viewed 8209 times
Demech
Post by Demech »
Thank you for your reply.
I have checked LCD pads and board pins but everything seems ok.
Any other suggestion?
Mark
Post by Mark »
no short out or bad soldering? that's weird...then you can download the firmware here see if it works:
