Missing Parts??? Prusa I3 Pro B
BrynGerard
Post by BrynGerard »
Hi Everyone,
I'm a newbie here and I've been enjoying building my I3 Pro B. I bought it last September but I had no time until now to get to it.
Everything has gone quite well with the 'removal of the protective paper' being the most difficult task so far :)
I've got to the point of :7.4 Assemble the X-axis rods and both ends, and Part 19 x 2 (locking screw) has to be 'screwed' on but alas there is no bolt in the threaded hole (see the attached image).
I see someone else had this problem, I've checked and they haven't fallen out in the bag. I see that part 20, (Bolt, Jimi headless M3x6mm) looks like the bolts that are missing. Are these the correct part to use? I see that you advised someone else that they should have been already threaded and I believe they purchased a replacement. Do I need to do this also?
Kind of stymied at this point, I don't want to discover that part 20 is needed for something else later. I'm sure I can get them local or off Ebay.
Thanks for any help!
Mark
Re: Missing Parts??? Prusa I3 Pro B
Post by Mark »
I remember it should be M5x6mm...but it's called Jimi, then that's the correct part I think..
BrynGerard
Thanks! that worked out fine.
