I've got a little problem with a LCD on a G2s pro.
When i start the printer the LCD screen is Ok, everything works (I can see temperature ect, ect) , i can click on the knob and saw the menu but when I start turning the knob the display become crazy and show strange caracters.
the only way to get it back working is to reset the printer.
Any suggestion ?
g2s pro lcd keypad
Re: g2s pro lcd keypad
Hi,FredFred77 wrote:Hi,
Any suggestion ?
first,you can swap the wire behind the LCD control panel with another new one,then if it doesn't help yet,upload the corresponding firmware once again.
Thank you,
I"ll try to change the wire, do you know where i can get brand new one ?
Dear Fred,Fred77 wrote:Thank you,
Maybe you could check the circuit related to LCD like the LCD control panel and the motherboard,and ensure there is the phenomenon of short-circuit.If there is not,then upload the corresponding firmware once again.If it all doesn't work,you can try to change the wire finally.
