Prusa I3 Pro B fails
Bernd
Post by Bernd »
Hi, I have a Prusa bought I3 Pro B on Ebay by Greetech, unfortunately I have so problems. First, I get no filament from the extruder, I checked everything and the motor rotates also correct the allen screws on the wheel I tightened. Unfortunately I do not screw to the extruder that I can increase the pressure on the filament. It looks as if the pressure is insufficient to the filament continues to transport. Second, the threaded rods and the normal bars are so crooked that they become wedged at work in the upper brackets and everything stops. So can not print it. The quality of these are really not good. Can I get compensation for it please.
Bernd
Re: Prusa I3 Pro B fails
Bernd wrote:Hi, I have a Prusa bought I3 Pro B on Ebay by Greetech, unfortunately I have so problems. First, I get no filament from the extruder, I checked everything and the motor rotates also correct the allen screws on the wheel I tightened. Unfortunately I do not screw to the extruder that I can increase the pressure on the filament. It looks as if the pressure is insufficient to the filament continues to transport. Second, the threaded rods and the normal bars are so crooked that they become wedged at work in the upper brackets and everything stops. So can not print it. The quality of these are really not good. Can I get compensation for it please.
Bernd
Hey,buddy
Don't worry.You can try as the link below shows,it may be helpful:
http://www.geeetech.com/forum/viewtopic ... 19&t=17097
Bernd
Post by Bernd »
I thank you for this link, but most I have already tried and has not helped, it looks as if the pressure is insufficient to the filament so as to continue to carry and unfortunately I have with my extruder not screw up to to increase the pressure.
extruder
extruder
Bernd wrote:I thank you for this link, but most I have already tried and has not helped, it looks as if the pressure is insufficient to the filament so as to continue to carry and unfortunately I have with my extruder not screw up to to increase the pressure.
The attachment extruder.png is no longer available
If everything is OK,it shouldn't be like this.And have you already checked your extruder carefully?Cuz i think the filament doesn't require that much pressure.Like the filament must stay in the groove of the driven wheel.Like the pic below shows:
In addition,its my opinion that if you wanna increase the pressure,you should have this one screw up,shouldn't it?
Bernd
Post by Bernd »
No sry i have this one.. and i have no screw !!!!
Bernd
Post by Bernd »
Bernd wrote:
All done and it doesn't work?
Bernd
Post by Bernd »
Nope, doesn´t works... grrrrrr !!!!!
Bernd
Post by Bernd »
No, sorry it doesn´t works ! I have try everything... but i think the pressure for the filament is to low. When i push the filament with my hand down the fila comes out of the nozzle.
