Prusa I3 Pro X doesnt print in the middle
CorpseGuard
Post by CorpseGuard »
Hey Guys i hope you can help me to solve my problem with my prusa.
I try to print an Object. But the printer starts to print in front of the plate here was a Photo:
Foto 14.06.16, 15 42 35.jpg (138.93 KiB) Viewed 14048 times
If i homing all axes the Y-Axis drive off the plate and dont stop on the left Corner. I changed everthing in the Reptier Host but nothing works.
I dont know how to solve the problem :(
I hope you can help me here
Re: Prusa I3 Pro X doesnt print in the middle
CorpseGuard wrote:Hey Guys i hope you can help me to solve my problem with my prusa.
Hey,buddy
Don't worry,look at this,it helps you set the printing center:
http://www.geeetech.com/forum/viewtopic ... 819#p27819
And for the wrong motor direction,check it like this:
http://www.geeetech.com/forum/viewtopic ... 17&t=17037
CorpseGuard
i did it so like your post but it has no effect.
CorpseGuard wrote:i did it so like your post but it has no effect.
Sorry,you mean the first problem or the second one?
CorpseGuard
The First one. Am I right that when I homing all axes that the extruder must be on the left corner of the plate?
When I put 22 steps in the Y axis on the manual mode of the printer the extruder was on the right position. But how can I save this position??
CorpseGuard wrote:The First one. Am I right that when I homing all axes that the extruder must be on the left corner of the plate?
Yep,you're right, the extruder must be on the left corner of the plate when you home all axes.
CorpseGuard
But it doesn't work :/ I try diffrent settings. Someone have the firmware for me? My last chance is arduino :/
CorpseGuard wrote:But it doesn't work :/ I try diffrent settings. Someone have the firmware for me? My last chance is arduino :/
CorpseGuard
If i have to do here my changes to change homeposition?
// Travel limits after homing
#define X_MAX_POS 205
#define X_MIN_POS 0
#define Y_MAX_POS 235
#define Y_MIN_POS 0
#define Z_MAX_POS 190
#define Z_MIN_POS 0
I think Y-Max is false. That must be 205 to come over the plate. Am i right?
CorpseGuard wrote:If i have to do here my changes to change homeposition?
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
Yep,you can have a try.
