Prusa I3 Pro B fails
syossi2
Re: Prusa I3 Pro B fails
Post by syossi2 »
hi
i was having same problem
so i dissapbled the barrel of the nozzle and found out that it come from the seller with half way teflon inside and with lot of jam defect inside it so the filament cant move there
once i cleane it all and put new teflon its working fine
thanks
yossi
printing 3D with M201 Geeetech
syossi2 wrote:hi
thanks
yossi
It's so kind of you,yossi.Maybe you can have a try.@Bernd
Bernd
Post by Bernd »
I can try, because it must be that it does not work indeed anything. Where did you get the new Teflon from to replace it?, And how did you get the old out of there?
Bernd
Post by Bernd »
I have looked at the nozzle in more detail, which should be 0.35 mm but it looks as if that is substantially smaller, it may be because the does not come out the filament?
syossi2
Post by syossi2 »
hi
i heat it up to 220 c when only the barrle is scrwe to the hotend, then i start to clean in up with niddle and some thin still
about the teflon, i alrady buy few weeks ago . its nice to have :)....
Bernd wrote:I have looked at the nozzle in more detail, which should be 0.35 mm but it looks as if that is substantially smaller, it may be because the does not come out the filament?
The filament doesn't matter to the size of your nozzle,but the groove size below.BTW,what size is your filament?
Bernd
Post by Bernd »
my size of Filament are 1,75 !
Bernd wrote:my size of Filament are 1,75 !
Hi,Bernd
Have you dismentled the extruder?If haven't ,you can dismentle it and check if everything is ok inside it.You can reference the video below about dismentling MK8 extruder:
https://www.youtube.com/watch?v=aPvVUZQnOMM
Regards
Bernd
Post by Bernd »
OK, I made for video, mine is not the same as in the video but it went. In Hotend everything was and by the rausmachen is also the Teflon broken. the next is the role the wobbles and if there is a ball bearing should be in there then I think that this is broken. Unfortunately, I can not take this one so apart like in the video. but since the error will be. Motor is OK, fan and heat sink also.
Bernd
Post by Bernd »
and this one here is plastic no aluminum metal as shown in the video! I just wanted to say again.
