Prusa I3 Pro B fails
syossi2
Re: Prusa I3 Pro B fails
Post by syossi2 »
hi
so like i sayd befor
i think you solutuion is in the barrel and the teflon
fix it whell ! clean it all! make shure that the teflon is all the way in !!
and then try agian
P.S. the teflon need to point down to the tip ( the teflon has to be with full contac with the tip)
good luck
yossi
printing 3D with M201 Geeetech
Bernd wrote:and this one here is plastic no aluminum metal as shown in the video! I just wanted to say again.
Yes,i know yours is plastic,i post it just for giving you a reference to dismentle your extruder...
Bernd
Post by Bernd »
ok ... unfortunately I have no Teflon and what I need as yet. This printer is new and therefore I have no spare parts here. Please can you this send?
Bernd wrote:ok ... unfortunately I have no Teflon and what I need as yet. This printer is new and therefore I have no spare parts here. Please can you this send?
er
Hey,buddy
Sorry to bring you the trouble.Was your nozzle diameter set the same as your nozzle's actual size in the printing settings(cuz i knew about your nozzle size is 0.3mm from our sales,and this setting will make a difference)?
If these are corresponding size to your nozzle and it doesn't work yet,then you can ask our seller for the replacement of Nozzle Throat & Teflon PTFE.
Bernd
Post by Bernd »
I now once again checked through everything and have found that the filament is not tranportiert. the filament is not pushed through this wheel forward see video. I can filament as by pushing calibration times .. that probably should not be so right?
Bernd wrote:I now once again checked through everything and have found that the filament is not tranportiert. the filament is not pushed through this wheel forward see video. I can filament as by pushing calibration times .. that probably should not be so right?
So,what you have tried something else and anything has changed?
Bernd
Post by Bernd »
sorry i have upload a video but it´s not there... i try it again but: The extension mp4 is not allowed.
now you can look here: https://youtu.be/MV0Uq8_1Gdo
syossi2
Post by syossi2 »
hi
what did you show us? that all works fine on the extruder?
i still say that the problen is in the barrle and the teflon and the tip
there you shulde check every thing
yossi
Bernd wrote:sorry i have upload a video but it´s not there... i try it again but: The extension mp4 is not allowed.
I saw your video carefully.I found the wheel(what i attach) didn't ronate when you moved the filament through it,am i right ?It seems the gap beween the two wheels is too large etc...How do you think?
Bernd
Post by Bernd »
yes you are right i can push the filament without the wheel rotate ! Although, if I do this with the engine built state rotates the gear from the motor but the filament remains on the spot.
