Z home with autolevel
Re: Z home with autolevel
qdshombre wrote:I plugged the 2 cables Y on Z min and the switch dont stop the bed on the Y axis.
Sorry,my mistake.What i actually want to tell you to do is replace the Z axis's endstop with the X axis's directly not the connectors,cuz i think you need to check if the endstop of Z axis is broken.
qdshombre
Post by qdshombre »
I don't understand the manipulation, can you explain? TY
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 - lit chauffant
qdshombre wrote:I don't understand the manipulation, can you explain? TY
That is to say,as you know there are 3 endstops in total(X axis,Y axis and Z axis).I mean you can uninstall the endstop installed the X axis or Y axis before,then install the uninstalled endstop to Z axis's position cuz you said the X and Y axis can home normally.
Regards
qdshombre
Post by qdshombre »
hello , I handed the endstop on the Z axis and the moving don't stop
qdshombre wrote:hello , I handed the endstop on the Z axis and the moving don't stop
That's weird!I saw you said it's open when you home Z axis and input M119?Generally speaking,it appears "triggered" or "on" not "open".And have you done what i told you?
Have a look at the pic i post to see if it will help:
qdshombre
Post by qdshombre »
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false;
I don't have never ''triggered'', always ''open''.
qdshombre wrote:// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
Could you plz attach a pic of the status after your inputing M119?Home your printer first
qdshombre
Post by qdshombre »
M119 (Copier).jpg (176.07 KiB) Viewed 11337 times
qdshombre wrote:
Did your sensors of all the axis touch their own endstop???if they did,there should be "on" or "triggered" not "open".You haven't home them fully???If you didn't,manually move them to the endstop position then input the "M119" to see what happens.If you did,check the connection between the endstop and the endstop's connector on the motherboard.
qdshombre
Post by qdshombre »
04:59:52.037 : x_min: TRIGGERED
04:59:52.037 : y_min: TRIGGERED
04:59:52.037 : z_min: open
I have with X and Y, not for Z
