X, Y homing direction is reversed [M201 Printer]
Hello, I just have finished assembling my new M201 printer. When homing, I noticed that the X, Y direction is opposite. Could you please help me how can I fix it? ANd, also please provide me the most recent stable firmware for this M201 printer with GTM 32. Thank you very much.
Re: X, Y homing direction is reversed [M201 Printer]
Hi,my friendkhondoke wrote:Hello, I just have finished assembling my new M201 printer. When homing, I noticed that the X, Y direction is opposite. Could you please help me how can I fix it? ANd, also please provide me the most recent stable firmware for this M201 printer with GTM 32. Thank you very much.
Don't worry.
1.About the wrong direction,cuz you use M201 and its motherboard is GTM32,so you can change the directiong in LCD controller panel.Follow this:
Control-> printer settings-> X/Y/Z/E motor direction
and then remember to save it here:
control -> store memory
2.About the latest firmware for M201,it is GTM32_V1.0.5.You can download it from here:
Good Day
Thanks William, I got new problem. Z-motors can't rotate and take the extruder carriage up/down. When I click on Z-homing, the motors create sound but can't rotate the lead screws. I checked the wiring and seems these are okay. Just one thing to mention, my X, Y and Z all motors are the same size and little bit smaller than what I have with my other Geeetech Pro C printer. Is it something that, I didn't receive the perfect motors? Here is the Z-motors spec I got with this M201 printer kit. Please check it and help me out to make it fully operational. Thank you very much.
The motor spec is 42SHD0034-20B.
I don't think it's the motor problem.
In some cases z axis motor won't run because the hole on the top plate for z thread rod is too tight,
I think you can remove the top plate and see if the motor will run, if so, I think the tightness of the hole is not proper,
you can get a 5/16" drill bit and using a precision drill to drill a straight and accurate hole,
or you can print this for top palte:
https://www.thingiverse.com/thing:1204200
Thanks. It works now.
