M201 - 2 extruders - one not moving
stevemcl
Post by stevemcl »
Hi, in the LCD menu, under prepare/move axis I can choose Extruder 0 and Extruder 1, and I choose 1.0 mm
extruder 0 moves fine when I select it, when I select Extruder 1, the motor doesn't move,
I do not have the hot end heated, should I be able to select each extruder and control the motor? or are they tied together?
thanks,
Re: M201 - 2 extruders - one not moving
stevemcl wrote:Hi, in the LCD menu, under prepare/move axis I can choose Extruder 0 and Extruder 1, and I choose 1.0 mm
thanks,
Yes,you can select each extruder and control it.And you can test if the extruder motor rotates by pressing the corresponding handle of each extruder.Have a look at a pic below:
