OK I think I have uploaded Marlin the to board. I have enabled the LCD
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
https://www.amazon.co.uk/gp/product/B00L72FAZU
When I plug the USB cable in the LCD doesn't light up or do anything, If I turn the control dial a yellow LED flashes on the board.
I have LCD to Exp 1 and SD Card to Exp 2 on the LCD board.
IF I sawp the cables around the only way I can get anything is when I put a SD card in, the screen back light comes on ad the buzzer sounds.
Starting out, getting LCD to work ?
Re: Starting out, getting LCD to work ?
Hi,MontyFlange wrote:OK I think I have uploaded Marlin the to board. I have enabled the LCD
What board are you using now?Have you uploaded the firmware successfully?What did the LCD12864 display when you turned on the power?Attach a video to show me how everything goes plz.
And you can refer the following article to double check the wiring plugs:
http://www.geeetech.com/forum/viewtopic ... =10#p29507
MontyFlange
Yer exactly the same problem. I just sanded off the tab on the cable end and turned it upside down.
