Etruder positions itself about 8mm above the print bed
robcowley
Post by robcowley »
I am totally new to all this so any help would be great i have just finsihed building my I3 pro X printer it all seems to work but when i try to print a object the extruder sits about 8mm above the print bed i leveled the bed and set the Z stop just paper thick above the bed?
HELP i am sick of it already lol
Re: Etruder positions itself about 8mm above the print bed
I think you can check if the X axis left end and right end are staying a same height.
robcowley
Post by robcowley »
I can only see the printing object didn't stick to the bed from your video...Are the two distance same?
And i think it's the abnormal anto home of Z axis caused it,you'd better observe Z endstop status when you auto home the printer:
robcowley
Post by robcowley »
Hi the print nozzle always seems to high above the bed ?
https://www.youtube.com/watch?v=Ux1qkp4zboA
i altered the levels on the Z axis so they are equal.
Thanks for your help hope someone can see where i am going wrong.
robcowley wrote:Hi the print nozzle always seems to high above the bed ?
Have you homed your Z axis before you level the heat bed?
robcowley
Post by robcowley »
Hi I home it then switch the steppers off to level the bed is that correct?
robcowley wrote:Hi I home it then switch the steppers off to level the bed is that correct?
Yes,you're right.How did you operate it before?
robcowley
Post by robcowley »
Hi that's how I have done all the time
