Changing Y axis to Extruder 2
TheSilentBoy
Post by TheSilentBoy »
Hi, my y-axis stopped moving and it doesn't receive power but when I put it on the x-axis port it moves and receives power. So is there a way to move my y-axis pins to my extruder 2 pins?
If you know how to change it, can you please tell me or change the firmware that I have included in this.
Re: Changing Y axis to Extruder 2
Have you checked the Y axis motor's driver A4988?Maybe it was broken,refer the following post to check it plz:
www.geeetech.com/forum/viewtopic.php?f=17&t=17038
TheSilentBoy
Hi, I connected my A4988 the right way where the middle circular thing facing downwards. I swapped the step driver all around and they still work but the y-axis still doesn't move. The jumpers are all connected.
TheSilentBoy wrote:Hi, I connected my A4988 the right way where the middle circular thing facing downwards. I swapped the step driver all around and they still work but the y-axis still doesn't move. The jumpers are all connected.
So it is,maybe the Y-motor port has a problem
Which board are you using now or what model is your printer?
1.If it is GTM32,it is not open source...I'm afraid you can't do that.
2.If it is GT2560,,you can modify the codes in the "pins.h" in the firmware.And the board is open source,sorry to tell you that you only can modify it by yourself:
TheSilentBoy
Hi, I do not know how to change the code. I have a GT2560 BOARD.
Google may help you.
TheSilentBoy
I searched it up but there's nothing but on Reprap forum is my question and both have no answers. Please can you do it. :D
TheSilentBoy wrote:I searched it up but there's nothing but on Reprap forum is my question and both have no answers. Please can you do it. :D
Sorry,i'd love to if i could.But i have to say,i'm not good at this :cry:
TheSilentBoy
Can you at least try. I tried to change the code but didn't work. At least trying is better than anything. Please
