Extruder switch off : MINTEMP when the wires move
hitjacker
Post by hitjacker »
I bought the Prusa i3 Pro B Acrylic, and I did few printing but I have a problem with the extruder's sensor. The temperature is ok but when the printing start, the contact with the sensor is lost with MINTEMP write on the LCD.
I try this : http://www.geeetech.com/forum/viewtopic ... 23&t=17030.
It's the case 1.2.4, but the problem comes from the wire which comes out to the extruder
Little video to show the problem : https://www.youtube.com/watch?v=Mp_pleu4r9Y
How can I solve this problem ?
Re: Extruder switch off : MINTEMP when the wires move
hitjacker wrote:Hi,
It's the connection problem.You'd better check if the thermistor on extruder has a good connection to the board.
hitjacker
Post by hitjacker »
Indeed I think the problem is the connection, that's why I did what there are explain on the topic "How to slove the problem of MAX/MIN TEMP error(GT2560)".
The sensor is correctly connect to the board, I check some times.
I see the problem is resolve only when I move the wire which are near the extruder (I try to show that in my video).
Toy
Post by Toy »
You need to check this part, in most cases the connection problem of thermistor is due to the poor contact here
hitjacker
Post by hitjacker »
Hi Toy,
Thanks for your help.
Indeed, the problem seem to be that : when I move the part, the contact is done.
How can I repair this ? I don't try to disassemble this, I wait your advice.
I think you just need to sort out the wirings and bind them together with the tape..
hitjacker
Post by hitjacker »
Problem solved, thanks :)
